跳转到主内容
加入维修社区 - 创建账户
Apple Studio Display M2454 USB port replacement
浏览量: 5161
浏览统计数据:
过去24小时
2
过去 7 天:
19
过去 30 天:
84
总计
5,161
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 1
1 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 3
3 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 15分钟
难度: 简单
缺少前提条件
本指南缺少关于如何开始这些步骤的信息。请编写前提指南!
There are two USB inputs on the Apple Studio Display M2454 monitor. If they are damaged and can not work properly they'll need to be replaced. The procedure for replacing these ports is simple however and should not require much time.
你所需要的
工具
    1. Apple Studio Display M2454 USB port replacement, USB Ports: 步骤 1 中的图像 1,1
      • The USB ports are located on the back side of the monitor, below the plastic cover and metallic panel; on the lower left hand side.
      • The first step is to remove the plastic cover panel.
      • To do so, remove the three 2mm hex screws on the monitor's stand, as well as the four 2mm hex screws located on the four corners of the back plastic cover panel.
      • After removing the mentioned screws, it is possible to take off the panels and began examining the inner components. Make sure main cable i pulled through plastic port.
      • For additional help removing the back panel, refer to the repair guide for the LCD Main Board.
      询问修复机器人
      添加评论
    2. Apple Studio Display M2454 USB port replacement: 步骤 2 中的图像 1,2 Apple Studio Display M2454 USB port replacement: 步骤 2 中的图像 2,2
      • Remove the three screws holding metal plate, one on the top in the middle, and two at the bottom by the main cable.
      • Remove the transparent plastic around the USB ports.
      • Push the metal plate towards bottom of the monitor to release it from clips and remove.
      • After popping off (removing) metal plate, you can now see all inner components, where the USB connector is on left side.
      询问修复机器人
      添加评论
    3. Apple Studio Display M2454 USB port replacement: 步骤 3 中的图像 1,1
      • There are two leads from the USB port to the LCD Main Board.
      • Remove the two white connectors by raising the tabs on top gently by hand or using a small pry tool.
      • Pull connectorss away from the board while tabs are lifted.
      • Be gentle with tabs, they break easily.
      询问修复机器人
      添加评论
    4. Apple Studio Display M2454 USB port replacement: 步骤 4 中的图像 1,1
      • Remove the two phillips head screws on the sides of USB port, using #2 phillips head screwdriver.
      询问修复机器人
      添加评论
    5. Apple Studio Display M2454 USB port replacement: 步骤 5 中的图像 1,1
      • Remove the single screw on the cable hold-down, using #2 phillips head screwdriver.
      询问修复机器人
      添加评论
    6. Apple Studio Display M2454 USB port replacement: 步骤 6 中的图像 1,1
      • Finally pull USB port away from monitor.
      • To insert the new USB port, simply follow these steps in reverse using your new part.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
作者
与
Dylan Perry
于01/20/10注册
177 声望
创作了5篇指南
团队
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G27
4 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 84
总计 5,161
