拆解
这个拆解是不是维修指南。 要维修你的的Apple Studio Display M2454,请使用我们的维修手册。
这个步骤还没有翻译 帮忙翻译一下
Notice that the main components of the monitor are only accessible from the back of the device.
Locate the four hex head screws located on the corners of the back panel.
Remove the screws with a 2mm hex screwdriver.
Remove the clear and gray back panels.
Remove the three screws with #2 phillips head screwdriver.
To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
Remove the four screws on the metal bracket.
Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
Remove white connector by lifting tab and pulling away from board.
Be careful when lifting tabs, they break easily.
Remove connector connected to the hold down previously removed simply by pulling with hand.
Now that the main computer cable is detached, remove it away from monitor.
Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
Remove the screw on the wire hold down with #2 Phillips head screwdriver.
Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
The USB port is now detached, remove it from monitor.
Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
Remove top right connector of the LCD main board by pulling with hand.
Remove the final connector of the LCD main board by pulling with hand.
Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
The board is now detached, remove it from monitor.
Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
This step may be easier with two people.
Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
The CCFL inverter is now detached, remove it from monitor.
You have now successfully taken apart a Apple Studio Display M2454.
与3其他贡献者
于01/20/10注册
177 声望
创作了5篇指南
徽章: 8
+ 5更多徽章
CPSU-MANESS-W10S13G27
4 名成员
创作了9篇指南
This model is also known as the Apple Studio Display 15" LCD.
analogcd - 2010年8月30日 回复
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - 2011年5月27日 回复
Failing caps were the main problem with this — no air flow.
Mal - 2018年3月15日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 7,615
