本指南有最近更改,您可查看未经巡查的最新版本。
简介
The main computer cable on the Apple Studio Display M2454 can be torn or cut and need to be replaced. Since this cable is what takes the signal from the computer and sends it to the monitor it's a vital part of the display. Thankfully, the procedure to fix it is relatively simple.
你所需要的
First, the back panel needs to be removed to access the cable connectors.
Locate the three 2mm hex screws located on the top of the stand and remove them.
Now locate and remove the four 2mm hex screws on the corners of the back panel.
Now remove the back panels while pulling the cable through them without damaging either part.
Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
Now remove the two other philips screws located below the cable with the philips head screwdriver.
With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
Pull the metal plate away.
With tape removed, the connections on the LCD main board can be disconnected.
First, remove the single hold-down using the philips head screwdriver.
Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
另外一个人完成了本指南。
