跳转到主内容
加入维修社区 - 创建账户
Apple Studio Display M2454 Main Computer Cable Replacement
你所需要的
    1. Apple Studio Display M2454 Main Computer Cable Replacement, Main Computer Cable: 步骤 1 中的图像 1,1
      • First, the back panel needs to be removed to access the cable connectors.
      • Locate the three 2mm hex screws located on the top of the stand and remove them.
      • Now locate and remove the four 2mm hex screws on the corners of the back panel.
      • Now remove the back panels while pulling the cable through them without damaging either part.
      询问修复机器人
      添加评论
    2. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 2 中的图像 1,1
      • Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
      • Now remove the two other philips screws located below the cable with the philips head screwdriver.
      • With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
      • Pull the metal plate away.
      询问修复机器人
      添加评论
    3. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 3 中的图像 1,1
      • Locate and remove the four #2 phillips screws located on the corners of the stand bracket, using the phillips head screwdriver.
      • Pull bracket away from monitor.
      询问修复机器人
      添加评论
    4. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 4 中的图像 1,1
      • Remove the cable hold-down with #2 phillips head screwdriver.
      询问修复机器人
      添加评论
    5. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 5 中的图像 1,1
      • Remove the screw at the bottom of the plastic bracket, using #2 phillips head screwdriver.
      • Pull the plastic bracket free.
      • Note the plastic pegs lining the bracket up with the monitor.
      询问修复机器人
      添加评论
    6. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 6 中的图像 1,1
      • Remove tape holding down the white connector to the LCD main board.
      询问修复机器人
      添加评论
    7. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 7 中的图像 1,1
      • With tape removed, the connections on the LCD main board can be disconnected.
      • First, remove the single hold-down using the philips head screwdriver.
      • Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
      • Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
      • The tabs can easily break off, be extra careful
      • Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
      询问修复机器人
      添加评论
    8. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 8 中的图像 1,1
      • Now remove the connection not on the LCD Main Board by pulling back the tape holding the wires down first.
      • Remove the connector by hand.
      询问修复机器人
      添加评论
    9. Apple Studio Display M2454 Main Computer Cable Replacement: 步骤 9 中的图像 1,1
      • Finally, the main cable can be replaced by pulling the old cable away and repeating the previous steps in reverse with a new, working main cable.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
Dylan Perry
于01/20/10注册
177 声望
创作了5篇指南
团队
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G27
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 41
总计 6,482
