跳转到主内容
加入维修社区 - 创建账户
Apple Studio Display M2454 LCD Main Board Replacement
你所需要的
  1. Apple Studio Display M2454 LCD Main Board Replacement, LCD Main Board: 步骤 1 中的图像 1,1
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
    询问修复机器人
    添加评论
  2. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 2 中的图像 1,1
    • Locate the three 2mm hex screws located on the back stand of the monitor.
    • These screws must be removed with the 2mm hex screwdriver in order for the back panel to be removed.
    询问修复机器人
    添加评论
  3. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 3 中的图像 1,1
    • Pull the clear back panel cover off.
    • Be sure to feed the cable through the back panel so no damage occurs.
    询问修复机器人
    添加评论
  4. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 4 中的图像 1,1
    • Now remove the back panel under the clear cover.
    • Again, feed the cable through the panel so no damage occurs.
    询问修复机器人
    添加评论
  5. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 5 中的图像 1,1
    • Remove the phillips head screw holding the back panel spacer with the phillips head screwdriver.
    询问修复机器人
    添加评论
  6. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 6 中的图像 1,1
    • Remove the two phillips head screws near the cable attachment with the phillips head screwdriver.
    询问修复机器人
    添加评论
  7. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 7 中的图像 1,2 Apple Studio Display M2454 LCD Main Board Replacement: 步骤 7 中的图像 2,2
    • To remove the metal plate covering the circuitry you need to push the cover towards the base of the monitor. (First remove any transparent plastic piece on the two USB connectors.)
    • If done correctly the tabs holding the plate should be detached and the plate will easily pop off.
    询问修复机器人
    添加评论
  8. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 8 中的图像 1,1
    • Now that the circuitry is exposed the boards can be seen and replaced.
    • The LCD Main Board is the largest board in the center of the device with seven external connections.
    询问修复机器人
    添加评论
  9. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 9 中的图像 1,1
    • Locate the four phillips head screws on the corners of the board.
    • Using the phillips head screwdriver, remove the four screws holding the board to the monitor.
    询问修复机器人
    添加评论
  10. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 10 中的图像 1,1
    • Remove the four braided connections simply by pushing the side of the connectors in and pull out.
    询问修复机器人
    添加评论
  11. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 11 中的图像 1,1
    • Remove the other two connectors by raising the tab on each either by hand or using a flat ended tool as shown.
    • Then gently pull away from the board to release tabs.
    • The tabs can easily break off, be extra careful.
    询问修复机器人
    添加评论
  12. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 12 中的图像 1,1
    • Remove the final black connector by pressing down on the back of the tab on the connector and then pull away from the board.
    • Be careful when holding onto the board while removing this connector or you risk pulling the board away too quickly and damaging the connector.
    询问修复机器人
    添加评论
  13. Apple Studio Display M2454 LCD Main Board Replacement: 步骤 13 中的图像 1,1
    • With all the connectors removed the board can be lifted away.
    • Now the new board can be attached by following the previous steps in reverse.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
Dylan Perry
于01/20/10注册
177 声望
创作了5篇指南
团队
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G27
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 66
总计 4,181
