跳转到主内容
修复你的物品
维修的权力
商店
简介
The CCFL Inverter is a vital part of the Apple Studio Display monitor and if it fails the monitor will have serious display problems. The CCFL inverter is what provides the backlight for the monitor. If it fails, the screen will essentially become black. This part, however, can be replaced with a new board relatively easily.
  1. First remove the three 2mm hex screws from the top of the monitors stand. Then, remove the four 2mm hex screws on the corners of the back panel.
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Remove the metal backing.
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Now, with the circuitry exposed, locate the CCFL inverter board.
    • Now, with the circuitry exposed, locate the CCFL inverter board.
    • Look for the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
  4. Now the connections from the board need to be removed.
    • Now the connections from the board need to be removed.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  5. Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  6. Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  7. Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
终点
另外一个人完成了本指南。
Dylan Perry
于2010年01月20日注册
144 信誉积分
创作了5篇指南
团队
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G27
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 16
总计 6,010
