跳转到主内容
Apple Powerbook 5300 Memory Replacement
你所需要的
  1. Apple Powerbook 5300 Memory Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Memory Replacement: 步骤 3 中的图像 1,1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Memory Replacement, Memory: 步骤 4 中的图像 1,1
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
结论
Scott
于04/26/11注册
155 声望
创作了5篇指南
团队
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G30
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 2,386
