跳转到主内容
Apple Powerbook 5300 Battery Replacement
  1. Apple Powerbook 5300 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G30
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,077
