跳转到主内容
Apple Powerbook 520/540 General Disassembly
你所需要的
  1. Apple Powerbook 520/540 General Disassembly, Case: 步骤 1 中的图像 1,2 Apple Powerbook 520/540 General Disassembly, Case: 步骤 1 中的图像 2,2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: 步骤 2 中的图像 1,1
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple Powerbook 520/540 General Disassembly: 步骤 3 中的图像 1,1
    • Remove top left and top right screws.
  4. Apple Powerbook 520/540 General Disassembly: 步骤 4 中的图像 1,1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: 步骤 5 中的图像 1,1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple Powerbook 520/540 General Disassembly: 步骤 6 中的图像 1,1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: 步骤 7 中的图像 1,3 Apple Powerbook 520/540 General Disassembly: 步骤 7 中的图像 2,3 Apple Powerbook 520/540 General Disassembly: 步骤 7 中的图像 3,3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
结论
9等其他人完成本指南。
Mark McNeff
于04/20/11注册
497 声望
创作了2篇指南
2条评论
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - 回复
Thanks been trying to fix this for a long time
Luke - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 48
总计 6,684
