跳转到主内容
Apple Powerbook 520 Floppy Drive Replacement
你所需要的
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: 步骤 1 中的图像 1,1
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: 步骤 3 中的图像 1,1
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: 步骤 4 中的图像 1,1
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: 步骤 7 中的图像 1,1
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: 步骤 8 中的图像 1,1
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
结论
2等其他人完成本指南。
Kevin Peters
于04/19/11注册
130 声望
撰写一个指南
团队
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G66
4 名成员
创作了3篇指南
一条评论
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 2,714
