跳转到主内容
Apple PowerBook G3 400 Display Replacement
你所需要的
  1. Apple PowerBook G3 400 Display Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 Display Replacement: 步骤 2 中的图像 1,1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 Display Replacement: 步骤 3 中的图像 1,1
    • Your computer should look approximately like this.
  4. Apple PowerBook G3 400 Display Replacement, RAM: 步骤 4 中的图像 1,1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
  5. Apple PowerBook G3 400 Display Replacement: 步骤 5 中的图像 1,1
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
  6. Apple PowerBook G3 400 Display Replacement: 步骤 6 中的图像 1,1
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
  7. Apple PowerBook G3 400 Display Replacement: 步骤 7 中的图像 1,1
    • Lift up the heat sink unit from the left side and remove.
  8. Apple PowerBook G3 400 Display Replacement: 步骤 8 中的图像 1,1
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
  9. Apple PowerBook G3 400 Display Replacement: 步骤 9 中的图像 1,1
    • After removing the RAM, your laptop should now look like this.
  10. Apple PowerBook G3 400 Display Replacement, Hard Drive: 步骤 10 中的图像 1,1
    • Locate the orange tab, which should be just left of the hard-drive.
    • You must disconnect this orange tab from the logic board to enable the next step.
    • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
  11. Apple PowerBook G3 400 Display Replacement: 步骤 11 中的图像 1,1
    • Grab the plastic strip shown here and gently remove, pulling up and left.
    • Pull left to avoid the hard drive catching the casing.
  12. Apple PowerBook G3 400 Display Replacement: 步骤 12 中的图像 1,1
    • Once you have removed the hard-drive, your laptop should like this.
  13. Apple PowerBook G3 400 Display Replacement, Modem: 步骤 13 中的图像 1,1
    • Remove the single black Torx screw from the modem.
    • Remove the black rectangle that is being held on by the one Torx screw.
  14. Apple PowerBook G3 400 Display Replacement: 步骤 14 中的图像 1,1
    • Using your fingers, lift the modem from the socket it is plugged into.
  15. Apple PowerBook G3 400 Display Replacement: 步骤 15 中的图像 1,1
    • Disconnect the cable that is attached to the end of the modem to remove the modem.
  16. Apple PowerBook G3 400 Display Replacement, Display: 步骤 16 中的图像 1,1
    • Your computer will look approximately like this.
  17. Apple PowerBook G3 400 Display Replacement: 步骤 17 中的图像 1,1
    • Push the display back.
    • Put your index finger under the power button and gently pull the clutch cover back.
    • Repeat for the left side.
  18. Apple PowerBook G3 400 Display Replacement: 步骤 18 中的图像 1,1
    • Lift the clutch cover up and off. Pull it towards yourself.
  19. Apple PowerBook G3 400 Display Replacement: 步骤 19 中的图像 1,1
    • Disconnect the display cable from the logic board.
  20. Apple PowerBook G3 400 Display Replacement: 步骤 20 中的图像 1,1
    • Remove the Torx screw that holds the display cable.
    • Pull out thick display inverter board by pulling it up and out. Two tabs will be holding it in place, you need to get pass these to pull the board free.
  21. Apple PowerBook G3 400 Display Replacement: 步骤 21 中的图像 1,1
    • Disconnect the white inverter cable. Pull it towards the left.
  22. Apple PowerBook G3 400 Display Replacement: 步骤 22 中的图像 1,1
    • Disconnect the inverter plug by pulling it up from the logib board.
  23. Apple PowerBook G3 400 Display Replacement: 步骤 23 中的图像 1,1
    • Turn the laptop around.
    • Open the port door.
    • Remove the four Torx screws.
  24. Apple PowerBook G3 400 Display Replacement: 步骤 24 中的图像 1,1
    • Turn the laptop so the front faces you.
    • Pull the black Airport antenna up.
  25. Apple PowerBook G3 400 Display Replacement: 步骤 25 中的图像 1,1
    • Pull the display up as you hold it firmly with both hands.
结论
Isabelle
于04/18/11注册
11 声望
撰写一个指南
团队
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011 的会员
CPSU-REGAN-S11S4G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,557
