跳转到主内容
Apple Lisa SCSI Card Installation
你所需要的
  1. Apple Lisa SCSI Card Installation, Disassembly: 步骤 1 中的图像 1,2 Apple Lisa SCSI Card Installation, Disassembly: 步骤 1 中的图像 2,2
  2. Apple Lisa SCSI Card Installation, Installing the SCSI Card: 步骤 2 中的图像 1,2 Apple Lisa SCSI Card Installation, Installing the SCSI Card: 步骤 2 中的图像 2,2
    • Locate Lisa's expansion slots.
    • Locate expansion slot 3.
    • Pull the metal rod out from slot 3 and rotate 90º clockwise.
    • Slide the SCSI Card into expansion slot 3.
    • Rotate the metal rod, as described before, 90º counter-clockwise and push in to secure the Lisa DAC.
    • The SCSI card includes 1 internal connector and 1 external connector.
    • The internal connector is used for connecting a hard disk.
    • If you intend to connect a hard disk then connect it now.
    • Pin 1 is marked.
    • The SCSI Card can also be cut to accommodate a Card Cage fan upon order request.
  3. Apple Lisa SCSI Card Installation, Reinstall Rear Panel: 步骤 4 中的图像 1,1
    • Reinstall the Lisa's rear panel.
  4. Apple Lisa SCSI Card Installation, Using the SCSI Card: 步骤 5 中的图像 1,1
    • The SCSI Card requires MacWorks Plus II.
    • To use devices connected to the SCSI card please refer to the device's manual for proper device installation.
    • This SCSI card was installed to use an Apple External SCSI CD-ROM Drive.
结论
LisaGuide
于12/30/18注册
1,833 声望
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 702
