跳转到主内容
Apple Lisa MacWorks II PFG Instalation
你所需要的
  1. Apple Lisa MacWorks II PFG Instalation, Disassembly: 步骤 1 中的图像 1,2 Apple Lisa MacWorks II PFG Instalation, Disassembly: 步骤 1 中的图像 2,2
  2. Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: 步骤 2 中的图像 1,2 Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: 步骤 2 中的图像 2,2
    • Remove the Lisa's I/O Board. The I/O Board's clips are marked in red.
    • Release both clips holding the I/O Board.
    • Pull the I/O Board up to remove it.
  3. Apple Lisa MacWorks II PFG Instalation, Removing the 8530 Chip: 步骤 3 中的图像 1,1
    • Remove the chip marked 8530 at location 9D.
  4. Apple Lisa MacWorks II PFG Instalation, Crystal Insulation: 步骤 4 中的图像 1,1
    • Next to the chip removed in step 3 is a crystal. These are not always installed with a plastic coating. The crystal shown in the image is insulated.
    • If your crystal is not insulated then tape a small piece of cardboard on top of it.
  5. Apple Lisa MacWorks II PFG Instalation, Installing the Daughter Board: 步骤 5 中的图像 1,1
    • Ensure the pins on the MW+II PFG (Programable Frequency Generator) are perfectly straight. If they are not then slightly bend them into place.
    • Insert the PFG into the 8530 socket.
  6. Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 步骤 6 中的图像 1,3 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 步骤 6 中的图像 2,3 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 步骤 6 中的图像 3,3
    • Locate the chip marked LS132 located at 6A.
    • Connect the Red and Black wires as shown in the second image on this step.
    • It is best to place a piece of electrical tape on the wires to help hold them in place.
  7. Apple Lisa MacWorks II PFG Instalation: 步骤 7 中的图像 1,1
    • Replace the I/O Board back into Lisa's Card Cage.
    • Replace Lisa's Card Cage Back into the Lisa.
    • Replace the rear panel on the Lisa.
    • MacWorks + II (MW+II) floppy images can be found here.
    • The MW+II manual can be found here which includes detailed instructions how to instal thel MW+II software.
结论
  • MW+II supports Macintosh System Software up to Macintosh System 7.5.5.
  • Supports over 10MB of RAM (more than 4MB requires an XLerator.)
另外一个人完成了本指南。
附加文件
LisaGuide
于12/30/18注册
1,833 声望
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 796
