跳转到主内容
Apple IIc Floppy Drive Replacement
你所需要的
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: 步骤 1 中的图像 1,2 Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: 步骤 1 中的图像 2,2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Floppy Drive Replacement: 步骤 2 中的图像 1,2 Apple IIc Floppy Drive Replacement: 步骤 2 中的图像 2,2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Floppy Drive Replacement: 步骤 3 中的图像 1,2 Apple IIc Floppy Drive Replacement: 步骤 3 中的图像 2,2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Floppy Drive Replacement: 步骤 4 中的图像 1,2 Apple IIc Floppy Drive Replacement: 步骤 4 中的图像 2,2
    • Lift the handle straight up to remove.
  5. Apple IIc Floppy Drive Replacement, Keyboard: 步骤 5 中的图像 1,2 Apple IIc Floppy Drive Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: 步骤 6 中的图像 1,2 Apple IIc Floppy Drive Replacement, Floppy Drive: 步骤 6 中的图像 2,2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Apple IIc Floppy Drive Replacement: 步骤 7 中的图像 1,3 Apple IIc Floppy Drive Replacement: 步骤 7 中的图像 2,3 Apple IIc Floppy Drive Replacement: 步骤 7 中的图像 3,3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Apple IIc Floppy Drive Replacement: 步骤 8 中的图像 1,2 Apple IIc Floppy Drive Replacement: 步骤 8 中的图像 2,2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Apple IIc Floppy Drive Replacement: 步骤 9 中的图像 1,2 Apple IIc Floppy Drive Replacement: 步骤 9 中的图像 2,2
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Apple IIc Floppy Drive Replacement: 步骤 10 中的图像 1,2 Apple IIc Floppy Drive Replacement: 步骤 10 中的图像 2,2
    • Lift the floppy drive straight up to remove.
结论
8等其他人完成本指南。
团队
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G23
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 5,918
