跳转到主内容
Apple EarPods Disassembly
你所需要的
  1. Apple EarPods Disassembly, Tools You Need: 步骤 1 中的图像 1,2 Apple EarPods Disassembly, Tools You Need: 步骤 1 中的图像 2,2
    • X-ACTO Knife
    • Tweezer
    • Triangle Paddle
    • Alcohol
    • Cotton Swabs
  2. Apple EarPods Disassembly, Opening Earpod: 步骤 2 中的图像 1,2 Apple EarPods Disassembly, Opening Earpod: 步骤 2 中的图像 2,2
    • Using a triangle paddle, apply sufficient pressure to get in-between the opening section
  3. Apple EarPods Disassembly, Cleaning Inside and Out: 步骤 3 中的图像 1,1
    • Soak one side of a cotton swab with alcohol
    • Clean inner and outer pod using swab soaked in alcohol
  4. Apple EarPods Disassembly, Cleaning the Speaker Cone: 步骤 4 中的图像 1,1
    • Carefully clean the speaker cone using cotton swab
    • Once clean, reattach the earbud
  5. Apple EarPods Disassembly, Removing the Grill: 步骤 5 中的图像 1,2 Apple EarPods Disassembly, Removing the Grill: 步骤 5 中的图像 2,2
    • Carefully remove grill out of both earbuds using tweezers
    • Take precautions not to bend grill excessively
  6. Apple EarPods Disassembly, Grill Polishing: 步骤 6 中的图像 1,1
    • Clean grill with cotton swab soaked in alcohol
    • Remove any build up of wax or sweat
  7. Apple EarPods Disassembly, Placing Grill Back: 步骤 7 中的图像 1,2 Apple EarPods Disassembly, Placing Grill Back: 步骤 7 中的图像 2,2
    • Once the grill is clean, place the grill back inside of the apple earbuds
结论
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
7等其他人完成本指南。
一条评论
When I re assemble they won’t stay closed. Do I glue them back together?
Patrick Appleby - 回复
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 144
过去 30 天: 604
总计 41,127
