跳转到主内容
Apple Cinema Display M8149 USB Port Replacement
你所需要的
  1. Apple Cinema Display M8149 USB Port Replacement, USB Port: 步骤 1 中的图像 1,3 Apple Cinema Display M8149 USB Port Replacement, USB Port: 步骤 1 中的图像 2,3 Apple Cinema Display M8149 USB Port Replacement, USB Port: 步骤 1 中的图像 3,3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Apple Cinema Display M8149 USB Port Replacement: 步骤 2 中的图像 1,3 Apple Cinema Display M8149 USB Port Replacement: 步骤 2 中的图像 2,3 Apple Cinema Display M8149 USB Port Replacement: 步骤 2 中的图像 3,3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Once the screws are removed, lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Apple Cinema Display M8149 USB Port Replacement: 步骤 3 中的图像 1,1
    • Unscrew the USB cable routing screw (8 x 2.72mm) using the PH 2 screwdriver.
  4. Apple Cinema Display M8149 USB Port Replacement: 步骤 4 中的图像 1,1
    • Unplug the USB cable connector from the screen box.
  5. Apple Cinema Display M8149 USB Port Replacement: 步骤 5 中的图像 1,2 Apple Cinema Display M8149 USB Port Replacement: 步骤 5 中的图像 2,2
    • Using the PH 2 screwdriver, unscrew the two screws (4.85 x 2.94mm) on the USB ports.
结论
Kyle Suguitan
于04/01/11注册
21 声望
撰写一个指南
团队
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G41
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 4,417
