跳转到主内容
Apple Airport Extreme Model A1408 Battery Replacement
你所需要的
  1. Apple Airport Extreme Model A1408 Battery Replacement, Back Pad: 步骤 1 中的图像 1,1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Battery Replacement: 步骤 2 中的图像 1,1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
  3. Apple Airport Extreme Model A1408 Battery Replacement, Outer Case: 步骤 3 中的图像 1,2 Apple Airport Extreme Model A1408 Battery Replacement, Outer Case: 步骤 3 中的图像 2,2
    • After removing the back pad, unscrew the five 5 mm Phillips #00 screws in the large, deep holes in the plastic casing. The plastic casing should come off easily after removing all the screws.
    • When installing the plastic back cover, ensure the lip is aligned with the ports on the back of the device.
  4. Apple Airport Extreme Model A1408 Battery Replacement: 步骤 4 中的图像 1,2 Apple Airport Extreme Model A1408 Battery Replacement: 步骤 4 中的图像 2,2
    • Insert a narrow plastic opening tool into one of the notches. Apply moderate force to pull the metal casing from the plastic outer casing. You can use the rim of the outer case as leverage. You should hear a click when the metal casing detaches.
    • After you hear the click, remove the inner metal case from the outer case using your hands. It should not take very much force.
  5. Apple Airport Extreme Model A1408 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Apple Airport Extreme Model A1408 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Wedge the tip of a plastic opening tool between the battery and the securing clip. Pop the battery out using sufficient leverage.
结论
3等其他人完成本指南。
Taiki Murakami
于10/14/14注册
176 声望
撰写一个指南
团队
Cal Poly, Team 10-37, Amido Fall 2014 Cal Poly, Team 10-37, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G37
4 名成员
创作了12篇指南
3条评论
Just Wondering, What is the Nomenclature , size and or specs of the internal battery A-1408 5th Generation have tried to find schematics to order a new
One but no dice. Bye the way you guys rock thank you so much, you may
E-Mail me at jcp512644@gmail.com
Jahn Peltz - 回复
The battery is BR2330 3V. That is 23mm diameter and 3mm thickness.
Martin Krencey -
Nice tutorial for sure!!!
Chrissy Michelle Strawn - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 4,118
