跳转到主内容
Apple Airport Extreme Model A1408 Back Pad Replacement
你所需要的
  1. Apple Airport Extreme Model A1408 Back Pad Replacement, Back Pad: 步骤 1 中的图像 1,1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Back Pad Replacement: 步骤 2 中的图像 1,1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
结论
To reassemble your device, follow these instructions in reverse order without using the hair dryer.
Jada Evers
于10/14/14注册
296 声望
创作了2篇指南
团队
Cal Poly, Team 10-37, Amido Fall 2014 Cal Poly, Team 10-37, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G37
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 2,065
