跳转到主内容
Apple AirPort Extreme Model A1354 Outer Case Replacement
你所需要的
  1. Apple AirPort Extreme Model A1354 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Outer Case Replacement: 步骤 2 中的图像 1,1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Outer Case Replacement: 步骤 3 中的图像 1,1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Outer Case Replacement: 步骤 4 中的图像 1,3 Apple AirPort Extreme Model A1354 Outer Case Replacement: 步骤 4 中的图像 2,3 Apple AirPort Extreme Model A1354 Outer Case Replacement: 步骤 4 中的图像 3,3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Outer Case Replacement: 步骤 5 中的图像 1,1
    • Remove the outer casing.
    • The exposed logic board should look like this.
结论
3等其他人完成本指南。
Brandon
于04/02/12注册
387 声望
创作了3篇指南
团队
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G2
5 名成员
创作了12篇指南
一条评论
This guide also applies to model A1408.
Jonas Nilsson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 4,301
