跳转到主内容
Apple AirPort Extreme Model A1354 Antenna Replacement
你所需要的
  1. Apple AirPort Extreme Model A1354 Antenna Replacement, Outer Case: 步骤 1 中的图像 1,1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 2 中的图像 1,1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 3 中的图像 1,1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 4 中的图像 1,3 Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 4 中的图像 2,3 Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 4 中的图像 3,3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 5 中的图像 1,1
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Apple AirPort Extreme Model A1354 Antenna Replacement, Antenna: 步骤 6 中的图像 1,1
    • Remove the metal casing by gently prying the logic board away with you hands.
    • This should be pretty easy, you already removed the screws holding these pieces together.
  7. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 7 中的图像 1,2 Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 7 中的图像 2,2
    • Turn the device so that the antenna to be replaced is facing you.
  8. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 8 中的图像 1,1
    • Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
    • Using the screwdriver, unscrew the 2.5mm Phillips screw on the antenna.
  9. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 9 中的图像 1,1
    • Turn the device over so that the antenna with the screw removed is still facing you.
  10. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 10 中的图像 1,1
    • Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
  11. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 11 中的图像 1,2 Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 11 中的图像 2,2
    • Carefully peel back the clear yellow tape covering the cable of the antenna to be removed.
  12. Apple AirPort Extreme Model A1354 Antenna Replacement: 步骤 12 中的图像 1,1
    • Remove the antenna.
结论
4等其他人完成本指南。
Brandon
于04/02/12注册
387 声望
创作了3篇指南
团队
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G2
5 名成员
创作了12篇指南
3条评论
Where do you get a new antenna from?
jimholewka - 回复
That's my question too. Where do we get a new antenna and wifi card to correct a poor signal?
jonathan - 回复
How will I receive an answer? jonathan@baylis.ca
jonathan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 12,213
