跳转到主内容
加入维修社区 - 创建账户
Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement
你所需要的
  1. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Back Pad: 步骤 1 中的图像 1,1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
    添加评论
  2. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Back Cover: 步骤 2 中的图像 1,1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
    询问修复机器人
    添加评论
  3. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 步骤 3 中的图像 1,1
    • Lift up the back case from the perforated edge to remove it.
    询问修复机器人
    添加评论
  4. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Remove from Case: 步骤 4 中的图像 1,1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
    添加评论
  5. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Detach Logic Board From Case: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
    询问修复机器人
    添加评论
  6. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Pull Back Tabs: 步骤 6 中的图像 1,1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
    询问修复机器人
    添加评论
  7. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Remove Metal case: 步骤 7 中的图像 1,1
    • Carefully pull the metal case away from the logic board.
    询问修复机器人
    添加评论
  8. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 8 中的图像 1,1
    • Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
    • Pull away antennas from metal case.
    询问修复机器人
    添加评论
  9. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 步骤 9 中的图像 1,2 Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 步骤 9 中的图像 2,2
    • Pull up the less visible silver tape that holds the antenna cords in place at the ends of the device using your fingers.
    • Remove clear yellow tape that holds the cords to the outer casing in the same manner.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G4
5 名成员
创作了10篇指南
2指南评论
Thanks for the guide.
Pulled mine apart to examine the battery inside. It measured above 3.1 volts - even though it has been in use since June 2008 (about 9 years).
Holes will be punched for access to the 5 screws so the rubber pad does not have to be removed if it needs to be opened in the future.
I may see about buying a new Ac adapter to power this Airport Extreme since that is probably why the status light on the front did not illuminate.
doctordon - 回复 分享
Completed this. Didnt use apple replacement antennas. Added 3 U.FL Mini PCI to RP-SMA Pigtails, drilled 3 holes and mounted 3 +9db antennas. My wifi finally reaches my garage
David Bunting - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 56
总计 2,347
