跳转到主内容
加入维修社区 - 创建账户
Apple AirPort Extreme Model A1143 Battery Replacement
你所需要的
  1. Apple AirPort Extreme Model A1143 Battery Replacement, Back Pad: 步骤 1 中的图像 1,1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Battery Replacement, Back Cover: 步骤 2 中的图像 1,1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Battery Replacement: 步骤 3 中的图像 1,1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Battery Replacement, Remove from Case: 步骤 4 中的图像 1,1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Battery Replacement, Detach Logic Board From Case: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Battery Replacement, Pull Back Tabs: 步骤 6 中的图像 1,1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Battery Replacement, Remove Metal case: 步骤 7 中的图像 1,1
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Battery Replacement, Battery: 步骤 8 中的图像 1,1
    • Gently slide out the battery with a small narrow tool such as a spudger. Insert a new 3V CR2450HR.
结论
6等其他人完成本指南。
Zak
于09/23/14注册
622 声望
创作了4篇指南
团队
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G4
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 30
总计 6,074
