跳转到主内容
Apple AirPort Extreme Model A1034 Motherboard Replacement
你所需要的
  1. Apple AirPort Extreme Model A1034 Motherboard Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 3 中的图像 1,2 Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 8 中的图像 1,2 Apple AirPort Extreme Model A1034 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
结论
2等其他人完成本指南。
Michael Garcia
于10/12/11注册
411 声望
创作了5篇指南
团队
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G15
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 19
总计 6,015
