跳转到主内容
Apple AirPort Extreme Model A1034 Internet Card Replacement
你所需要的
  1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Internet Card Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Internet Card Replacement: 步骤 3 中的图像 1,2 Apple AirPort Extreme Model A1034 Internet Card Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Internet Card Replacement: 步骤 4 中的图像 1,1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: 步骤 5 中的图像 1,1
    • Remove four 1mm phillips screws from the bottom.
  6. Apple AirPort Extreme Model A1034 Internet Card Replacement: 步骤 6 中的图像 1,1
    • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
结论
3等其他人完成本指南。
Michael Garcia
于10/12/11注册
411 声望
创作了5篇指南
团队
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G15
3 名成员
创作了13篇指南
一条评论
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 5,176
