跳转到主内容
你所需要的
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: 步骤 3 中的图像 1,2 Apple AirPort Extreme Model A1034 Antenna Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: 步骤 4 中的图像 1,1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: 步骤 5 中的图像 1,1
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: 步骤 6 中的图像 1,1
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
结论
另外一个人完成了本指南。
Michael Garcia
于2011年10月12日注册
411 声望
创作了5篇指南
团队
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G15
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 4,546
