简介
Use this guide if you need to replace the heating element of your Apalus Digital Hair Straightening Brush. If your brush is not heating up, this guide will walk you through how to take apart the brush in order to replace the heating element. Soldering is involved, so if you don't know how to solder take a look at this 如何焊接和拆焊 guide.
你所需要的
There are 4 solder points of the heating element located on the LCD side of the circuit board.
Desolder these four connections using a soldering iron.
Note which wires go to each of the connection points.
