跳转到主内容
Anne Pro 2 Keyboard Keycaps Replacement
你所需要的
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: 步骤 1 中的图像 1,1
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: 步骤 2 中的图像 1,3 Anne Pro 2 Keyboard Keycaps Replacement: 步骤 2 中的图像 2,3 Anne Pro 2 Keyboard Keycaps Replacement: 步骤 2 中的图像 3,3
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: 步骤 3 中的图像 1,2 Anne Pro 2 Keyboard Keycaps Replacement: 步骤 3 中的图像 2,2
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: 步骤 4 中的图像 1,1
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: 步骤 5 中的图像 1,1
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
终点
另外一个人完成了本指南。
Omar Sukkar
于11/24/20注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 2,378
