跳转到主内容
Anne Pro 2 Case/Housing Replacement
你所需要的
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: 步骤 1 中的图像 1,3 Anne Pro 2 Case/Housing Replacement, Case/Housing: 步骤 1 中的图像 2,3 Anne Pro 2 Case/Housing Replacement, Case/Housing: 步骤 1 中的图像 3,3
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: 步骤 2 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 2 中的图像 2,2
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: 步骤 3 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 3 中的图像 2,2
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: 步骤 4 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: 步骤 5 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 5 中的图像 2,2
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: 步骤 6 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 6 中的图像 2,2
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: 步骤 7 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 7 中的图像 2,2
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: 步骤 8 中的图像 1,2 Anne Pro 2 Case/Housing Replacement: 步骤 8 中的图像 2,2
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
结论
2等其他人完成本指南。
Mohamed
于09/15/20注册
205 声望
撰写一个指南
团队
1指南评论
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 86
总计 11,575
