跳转到主内容
Anki Vector Infrared Sensor Replacement
你所需要的
  1. Anki Vector Infrared Sensor Replacement, Belts: 步骤 1 中的图像 1,1
    • Raise Vector's arms above his head.
  2. Anki Vector Infrared Sensor Replacement: 步骤 2 中的图像 1,2 Anki Vector Infrared Sensor Replacement: 步骤 2 中的图像 2,2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
  3. Anki Vector Infrared Sensor Replacement, Infrared Sensor: 步骤 3 中的图像 1,2 Anki Vector Infrared Sensor Replacement, Infrared Sensor: 步骤 3 中的图像 2,2
    • Pull each front wheel cover off.
    • This will require a good amount of force due to the three clips holding it in place.
  4. Anki Vector Infrared Sensor Replacement: 步骤 4 中的图像 1,2 Anki Vector Infrared Sensor Replacement: 步骤 4 中的图像 2,2
    • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
  5. Anki Vector Infrared Sensor Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two body screws beneath the wheel using the same screwdriver.
  6. Anki Vector Infrared Sensor Replacement: 步骤 6 中的图像 1,2 Anki Vector Infrared Sensor Replacement: 步骤 6 中的图像 2,2
    • Gently pull off the front panel to unplug the Infrared sensor.
    • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
结论
Shay Takei
于04/16/19注册
1,777 声望
创作了5篇指南
团队
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G6
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 894
