跳转到主内容
加入维修社区 - 创建账户
Anki Vector Belts Replacement
  1. Anki Vector Belts Replacement, Belts: 步骤 1 中的图像 1,1
    • Raise Vector's arms above his head.
  2. Anki Vector Belts Replacement: 步骤 2 中的图像 1,2 Anki Vector Belts Replacement: 步骤 2 中的图像 2,2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
结论
另外一个人完成了本指南。
Shay Takei
于04/16/19注册
1,777 声望
创作了5篇指南
团队
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G6
4 名成员
创作了10篇指南
1指南评论
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
PrestoStore - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 19
总计 1,427
