跳转到主内容
Anki Cozmo Speaker Replacement
你所需要的
  1. Anki Cozmo Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Anki Cozmo Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Remove the two black rubber treads from the wheels using your hands to pull them off.
  2. Anki Cozmo Speaker Replacement: 步骤 2 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
    • There are four white hubcaps removed in this step.
  3. Anki Cozmo Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
  4. Anki Cozmo Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
  5. Anki Cozmo Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
  6. Anki Cozmo Speaker Replacement: 步骤 6 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
  7. Anki Cozmo Speaker Replacement: 步骤 7 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the front gold bumper using your hands and fingers to pull it off.
  8. Anki Cozmo Speaker Replacement: 步骤 8 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 8 中的图像 2,2
    • Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
    • One screw is towards the front wheel and one screw is towards the back wheel.
  9. Anki Cozmo Speaker Replacement: 步骤 9 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 9 中的图像 2,2
    • Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
    • Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
    • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
  10. Anki Cozmo Speaker Replacement: 步骤 10 中的图像 1,3 Anki Cozmo Speaker Replacement: 步骤 10 中的图像 2,3 Anki Cozmo Speaker Replacement: 步骤 10 中的图像 3,3
    • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
  11. Anki Cozmo Speaker Replacement: 步骤 11 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 11 中的图像 2,2
    • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
  12. Anki Cozmo Speaker Replacement: 步骤 12 中的图像 1,1
    • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
  13. Anki Cozmo Speaker Replacement: 步骤 13 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 13 中的图像 2,2
    • Remove the right side of the white head using your hands and fingers to pull it off.
    • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
  14. Anki Cozmo Speaker Replacement: 步骤 14 中的图像 1,1
    • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
  15. Anki Cozmo Speaker Replacement: 步骤 15 中的图像 1,1
    • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
  16. Anki Cozmo Speaker Replacement: 步骤 16 中的图像 1,2 Anki Cozmo Speaker Replacement: 步骤 16 中的图像 2,2
    • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
    • The camera and the speaker are attached to each other. They are removed in the same step.
结论
另外一个人完成了本指南。
Marisa Gay
于10/28/21注册
617 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G8
3 名成员
创作了7篇指南
一条评论
Great, do you know where to buy the speaker ?
Gilberto Torres - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 44
总计 2,074
