跳转到主内容
Anker Soundcore Space Q45 Bluetooth Module Replacement
你所需要的
  1. Anker Soundcore Space Q45 Bluetooth Module Replacement, Plastic Covering: 步骤 1 中的图像 1,1
    • Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
    • Clips at 3 o'clock, 7 o'clock and 11 o'clock
    • Image shows right headphone, battery is in left.
  2. Anker Soundcore Space Q45 Bluetooth Module Replacement: 步骤 2 中的图像 1,2 Anker Soundcore Space Q45 Bluetooth Module Replacement: 步骤 2 中的图像 2,2
    • Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
  3. Anker Soundcore Space Q45 Bluetooth Module Replacement, Motherboard: 步骤 3 中的图像 1,2 Anker Soundcore Space Q45 Bluetooth Module Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove two screws from the motherboard with a Phillips screwdriver.
    • Remove the motherboard from the headphones.
    • Insert your new motherboard
  4. Anker Soundcore Space Q45 Bluetooth Module Replacement, Bluetooth Module: 步骤 4 中的图像 1,1
    • Use a soldering iron to desolder the connection from the Bluetooth receiver.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 4-3, Shaddix Spring 2024 UMass Dartmouth, Team 4-3, Shaddix Spring 2024 的会员
UMASSD-SHADDIX-S24S4G3
5 名成员
创作了10篇指南
3指南评论
please tell me the model of this microcircuit chip
Мидхат Миннурович - 回复
I have the sane question.. what is that chip??!! anyone???
GJN - 回复
answering myself and others out there who have their headphones stopped charging..its not the bluetooth chip.. its an IC chip..this seems to be a common problem.. the chip is ETA40543, and its not very commonly available, but you can find it on Aliexpress, about 1$ a piece.
GJN - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 652
