简介
Is your Anker Soundcore Space Q45 battery not holding a charge like it used to, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few simple steps. This guide will require you to remove the outer casing of the left headphone to access the battery.
你所需要的
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
另外一个人完成了本指南。
