跳转到主内容
Anker Soundcore Flare Mini Audio Drivers Replacement
你所需要的
  1. Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
  2. Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 2 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 2 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 2 中的图像 3,3
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
  3. Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: 步骤 3 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: 步骤 3 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
  4. Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 4 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 4 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
  5. Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: 步骤 5 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: 步骤 5 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: 步骤 5 中的图像 3,3
    • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
    • Remove the white plastic cover from the speaker.
  6. Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 6 中的图像 1,2 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 6 中的图像 2,2
    • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
  7. Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 7 中的图像 1,1
    • Pull the charging port away from the side of the speaker.
  8. Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 8 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 8 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to loosen the cover from the inner components of the speaker.
    • Slide the cover completely off.
    • One wire will still be connected to the shell.
  9. Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: 步骤 9 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: 步骤 9 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: 步骤 9 中的图像 3,3
    • There are two drivers—one on each side of the speaker.
    • Use a Phillips #1 screwdriver to remove the four 11 mm screws from one driver.
    • Use your hand to pull the driver out of the device.
    • Repeat this step with the other driver.
  10. Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 10 中的图像 1,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 10 中的图像 2,3 Anker Soundcore Flare Mini Audio Drivers Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • Use precision tweezers to detach the two wire connectors from the driver.
    • Both drivers are connected to the same wire so removing one side will separate the other driver from the device as well.
    • Remove both drivers from the device.
结论
1指南评论
what size are the speakers?
Chris - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 26
总计 1,252
