你所需要的
Insert a spudger between the front panel and the body of the speaker.
Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
Use your hand to remove the speakers.
另外一个人完成了本指南。
3条评论
Where can I buy the C34 and ESD4?
Do you know where to fond an Anker motherboard please?
