跳转到主内容
Anker 2.4G Wireless Mouse Scroll Wheel Replacement
你所需要的
  1. Anker 2.4G Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,1
    • Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
  2. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
  3. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 3 中的图像 1,2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
  4. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 4 中的图像 1,1
    • Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
    • Don't pull the wires too hard, as they might break.
  5. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 5 中的图像 1,2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 5 中的图像 2,2
    • Pull the scroll wheel put parallel to the board.
    • This may take some force to remove. Pull the scroll wheel out parallel to the board rather than perpendicular to it.
    • Replace/clean if needed.
    • If your mouse still does not work after this step, then continue to the next instruction.
  6. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 步骤 6 中的图像 1,1
    • Desolder the three pins, then solder in the replacement part.
结论
Vincent Lee
于01/23/14注册
361 声望
创作了3篇指南
团队
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G39
4 名成员
创作了16篇指南
一条评论
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 53
总计 8,421
