跳转到主内容
Anker 2.4G Wireless Mouse LED Replacement
你所需要的
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: 步骤 1 中的图像 1,1
    • Use a spudger to gently pry off the stickers to reveal the location of the four screws.
  2. Anker 2.4G Wireless Mouse LED Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: 步骤 3 中的图像 1,2 Anker 2.4G Wireless Mouse LED Replacement: 步骤 3 中的图像 2,2
    • Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: 步骤 4 中的图像 1,1
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: 步骤 5 中的图像 1,2 Anker 2.4G Wireless Mouse LED Replacement: 步骤 5 中的图像 2,2
    • Take the upper housing of the mouse and remove the two screws that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: 步骤 6 中的图像 1,1
    • Gently remove the circuit board from the mouse.
  7. Anker 2.4G Wireless Mouse LED Replacement: 步骤 7 中的图像 1,1
    • To remove the LED, flip the board over and desolder the wires.
    • Replace LED with a new LED and resolder into place.
结论
Colin
于02/10/14注册
406 声望
创作了3篇指南
团队
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G39
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 2,920
