跳转到主内容
Anker 2.4G Wireless Mouse Battery Replacement
你所需要的
  1. Anker 2.4G Wireless Mouse Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
  2. Anker 2.4G Wireless Mouse Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery with a finger nail or a nonmetal tool.
结论
另外一个人完成了本指南。
Vincent Lee
于01/23/14注册
361 声望
创作了3篇指南
团队
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G39
4 名成员
创作了16篇指南
2条评论
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - 回复
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
Rick Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 5,526
