跳转到主内容
加入维修社区 - 创建账户
Angelcare AC401 Baby Monitor Disassembly
你所需要的
  1. Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: 步骤 1 中的图像 1,2 Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: 步骤 1 中的图像 2,2
    • first remove the 2 screws at the green plastic plate.
    询问修复机器人
    添加评论
  2. Angelcare AC401 Baby Monitor Disassembly: 步骤 2 中的图像 1,1
    • remove the plastic plate ( battery compartment)
    • you'll see that there are 2 more screws. Remove them.
    询问修复机器人
    添加评论
  3. Angelcare AC401 Baby Monitor Disassembly: 步骤 3 中的图像 1,2 Angelcare AC401 Baby Monitor Disassembly: 步骤 3 中的图像 2,2
    • now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
    询问修复机器人
    添加评论
  4. Angelcare AC401 Baby Monitor Disassembly: 步骤 4 中的图像 1,2 Angelcare AC401 Baby Monitor Disassembly: 步骤 4 中的图像 2,2
    • now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
    • be carefull for the electric wires.
    询问修复机器人
    添加评论
  5. Angelcare AC401 Baby Monitor Disassembly: 步骤 5 中的图像 1,2 Angelcare AC401 Baby Monitor Disassembly: 步骤 5 中的图像 2,2
    • 2 battery's were exploded so the acid was on the black electric power wire.
    • use a cotton swab with a little bit of destilled water.
    询问修复机器人
    添加评论
  6. Angelcare AC401 Baby Monitor Disassembly: 步骤 6 中的图像 1,1
    • remove the 2 PCB's by removing the screws shown in the picture.
    询问修复机器人
    添加评论
  7. Angelcare AC401 Baby Monitor Disassembly: 步骤 7 中的图像 1,1
    • pull the first PCB up and remove the screws of the second PCB.
    • after removing the two PCB's, clean the acid on the PCB.
    • after cleaning the PCB's put it al together again.
    询问修复机器人
    添加评论
    • first remove the battery lid. 1 screw.
    • slide it out like you see in picture
    • remove battery's
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Kevin D
于05/02/14注册
7,550 声望
创作了21篇指南
13指南评论
Thanks for this. I couldn't figure out how to get the blue clip off without breaking it to clean some dirt on the screen. Googled it, found this, job done.
Pete H - 回复 分享
Sometimes the activity of the reference quartz is 11,150 MHz, and the devices do not find each other.
I have so repaired the parent module.
Dmitriy, the city of Volzhsky.
Dmitriy N - 回复 分享
Hi Dimitriy - I am experiencing the issue with not finding devices each other. How have you fix it ? Is it a matter of replacing the reference quartz with new one ?
Jan - 回复 分享
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Terese Rehn - 回复 分享
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 46
总计 15,860
