跳转到主内容
Android tablet Nobis NB09 Screen Replacement
你所需要的
  1. Android tablet Nobis NB09 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Android tablet Nobis NB09 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Android tablet Nobis NB09 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: 步骤 2 中的图像 1,3 Android tablet Nobis NB09 Screen Replacement: 步骤 2 中的图像 2,3 Android tablet Nobis NB09 Screen Replacement: 步骤 2 中的图像 3,3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: 步骤 3 中的图像 1,3 Android tablet Nobis NB09 Screen Replacement: 步骤 3 中的图像 2,3 Android tablet Nobis NB09 Screen Replacement: 步骤 3 中的图像 3,3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: 步骤 4 中的图像 1,3 Android tablet Nobis NB09 Screen Replacement: 步骤 4 中的图像 2,3 Android tablet Nobis NB09 Screen Replacement: 步骤 4 中的图像 3,3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
结论
4等其他人完成本指南。
Enea Osmann
于10/31/14注册
158 声望
撰写一个指南
团队
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G1
4 名成员
创作了12篇指南
2指南评论
The digitizer replacement instructions was great. Thanks
steven warren - 回复
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,598
