跳转到主内容
Android tablet Nobis NB09 Camera Replacement
你所需要的
  1. Android tablet Nobis NB09 Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two 00 Phillips screws located in the right hand side of the tablet.
  2. Android tablet Nobis NB09 Camera Replacement: 步骤 2 中的图像 1,3 Android tablet Nobis NB09 Camera Replacement: 步骤 2 中的图像 2,3 Android tablet Nobis NB09 Camera Replacement: 步骤 2 中的图像 3,3
    • Use plastic opening tools to loosen and pry off the back plate (pink piece).
    • When removing the cover, be careful not to pull too hard as there are wires connected to the motherboard attached to the back cover.
  3. Android tablet Nobis NB09 Camera Replacement, Camera: 步骤 3 中的图像 1,2 Android tablet Nobis NB09 Camera Replacement, Camera: 步骤 3 中的图像 2,2
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Start by removing the electrical tape covering the camera, located at the top left corner of the device.
    • Remove enough tape to expose the ZIF connector and the camera.
  4. Android tablet Nobis NB09 Camera Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Lift up the black plastic lock on the ZIF connector with tweezers.
    • ZIF stands for Zero Insertion Force connector. Make sure the connector is unlocked completely.
  5. Android tablet Nobis NB09 Camera Replacement: 步骤 5 中的图像 1,2 Android tablet Nobis NB09 Camera Replacement: 步骤 5 中的图像 2,2
    • Gently remove the camera by removing the power cord with tweezers. The camera should release easily: do not twist or pull too hard.
    • Replace the camera with a new one.
结论
To reassemble your device, follow these instructions in reverse order. Do not forget to put electrical tape back in place.
另外一个人完成了本指南。
Sergey Kasyanov
于03/26/15注册
237 声望
创作了2篇指南
团队
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 268
