跳转到主内容
Andoer HDV 107 Battery Replacement
  1. Andoer HDV 107 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture.
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Battery Replacement: 步骤 2 中的图像 1,1
    • You will see the battery being held in place by a clear plastic kickstand.
    • Use your finger to move the kickstand away from the battery.
  3. Andoer HDV 107 Battery Replacement: 步骤 3 中的图像 1,1
    • With your other hand press down on the battery slightly and remove the battery.
    • If the battery does not come out right away try to line the battery up with the sides to give it a clear path out of the compartment.
结论
Isaac Saron
于03/20/17注册
516 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 364
