跳转到主内容
Andobil Easy Clip Car Mount Replacement
你所需要的
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: 步骤 1 中的图像 1,1
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: 步骤 2 中的图像 1,1
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: 步骤 3 中的图像 1,2 Andobil Easy Clip Car Mount Replacement: 步骤 3 中的图像 2,2
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: 步骤 4 中的图像 1,1
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: 步骤 5 中的图像 1,2 Andobil Easy Clip Car Mount Replacement: 步骤 5 中的图像 2,2
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: 步骤 6 中的图像 1,1
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: 步骤 7 中的图像 1,1
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: 步骤 8 中的图像 1,1
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: 步骤 9 中的图像 1,1
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: 步骤 10 中的图像 1,1
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
结论
另外一个人完成了本指南。
Alexander Tavares
于03/24/21注册
205 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 78
总计 2,775
