跳转到主内容
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
你所需要的
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: 步骤 1 中的图像 1,3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: 步骤 1 中的图像 2,3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: 步骤 1 中的图像 3,3
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: 步骤 2 中的图像 1,3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: 步骤 2 中的图像 2,3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: 步骤 2 中的图像 3,3
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: 步骤 3 中的图像 1,2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: 步骤 3 中的图像 2,2
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: 步骤 4 中的图像 1,2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: 步骤 4 中的图像 2,2
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: 步骤 5 中的图像 1,2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: 步骤 5 中的图像 2,2
    • Clean or lubricate the device if necessary.
结论
2等其他人完成本指南。
David Taylor
于10/08/14注册
151 声望
撰写一个指南
团队
USF Tampa, Team 1-34, Donnelly Fall 2014 USF Tampa, Team 1-34, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G34
1 名成员
创作了1篇指南
一条评论
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 42
总计 6,791
