跳转到主内容
Anbernic RG35XXSP Speaker Replacement
你所需要的
  1. Anbernic RG35XXSP Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Anbernic RG35XXSP Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Anbernic RG35XXSP Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Power the device off before starting the disassembly process.
    • Close the device and turn it over so the bottom faces upward.
  2. Anbernic RG35XXSP Speaker Replacement: 步骤 2 中的图像 1,2 Anbernic RG35XXSP Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Speaker Replacement: 步骤 3 中的图像 1,2 Anbernic RG35XXSP Speaker Replacement: 步骤 3 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Speaker Replacement: 步骤 4 中的图像 1,3 Anbernic RG35XXSP Speaker Replacement: 步骤 4 中的图像 2,3 Anbernic RG35XXSP Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Speaker Replacement: 步骤 5 中的图像 1,3 Anbernic RG35XXSP Speaker Replacement: 步骤 5 中的图像 2,3 Anbernic RG35XXSP Speaker Replacement: 步骤 5 中的图像 3,3
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Anbernic RG35XXSP Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Lift up the green sheet of paper from the motherboard.
  7. Anbernic RG35XXSP Speaker Replacement: 步骤 7 中的图像 1,3 Anbernic RG35XXSP Speaker Replacement: 步骤 7 中的图像 2,3 Anbernic RG35XXSP Speaker Replacement: 步骤 7 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws that secure the motherboard.
    • Lift up the motherboard from the main body and flip it to the other side to reveal the speaker.
  8. Anbernic RG35XXSP Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the speaker from the device.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 215
