跳转到主内容
Anbernic RG35XXSP Case Replacement
你所需要的
  1. Anbernic RG35XXSP Case Replacement, Battery: 步骤 1 中的图像 1,3 Anbernic RG35XXSP Case Replacement, Battery: 步骤 1 中的图像 2,3 Anbernic RG35XXSP Case Replacement, Battery: 步骤 1 中的图像 3,3
    • Power the device off before starting the disassembly process.
    • Close the device and turn it over so the bottom faces upward.
  2. Anbernic RG35XXSP Case Replacement: 步骤 2 中的图像 1,2 Anbernic RG35XXSP Case Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Case Replacement: 步骤 3 中的图像 1,2 Anbernic RG35XXSP Case Replacement: 步骤 3 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Case Replacement: 步骤 4 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 4 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 4 中的图像 3,3
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Case Replacement: 步骤 5 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 5 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 5 中的图像 3,3
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Case Replacement, Motherboard: 步骤 6 中的图像 1,2 Anbernic RG35XXSP Case Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Lift up the green sheet of paper from the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws from the motherboard.
  7. Anbernic RG35XXSP Case Replacement: 步骤 7 中的图像 1,2 Anbernic RG35XXSP Case Replacement: 步骤 7 中的图像 2,2
    • Be careful when moving the motherboard as it is connected to the display ribbon cable, and can be damaged if pulled on.
    • Pick up the motherboard and flip it over.
  8. Anbernic RG35XXSP Case Replacement: 步骤 8 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 8 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 8 中的图像 3,3
    • Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the display cable out of its socket.
    • Remove the motherboard.
  9. Anbernic RG35XXSP Case Replacement, Case: 步骤 9 中的图像 1,3 Anbernic RG35XXSP Case Replacement, Case: 步骤 9 中的图像 2,3 Anbernic RG35XXSP Case Replacement, Case: 步骤 9 中的图像 3,3
    • Use a Phillips #00 to remove the single 5 mm screw located next to the display ribbon cable.
    • Flip the device over so it's facing up and remove the loose plastic hinge cover.
  10. Anbernic RG35XXSP Case Replacement: 步骤 10 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 10 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 10 中的图像 3,3
    • Use the pointed end of a spudger to push out the pin from the edge of the hinges.
    • Use tweezers to pull both the plastic covering the pin and the pin itself.
  11. Anbernic RG35XXSP Case Replacement: 步骤 11 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 11 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 11 中的图像 3,3
    • Use a spudger to pry off plastic screw covers from the screws around the edge of the screen.
    • Use a Phillips #00 screwdriver to remove the five 5 mm screws around the bezel of the screen.
  12. Anbernic RG35XXSP Case Replacement: 步骤 12 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 12 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 12 中的图像 3,3
    • Place the end of a spudger in between the two layers of the screen cover and pry it open.
    • Remove the screen from the plastic casing.
    • Be sure not to apply too much pressure on the screen as it is very thin and prone to cracking.
  13. Anbernic RG35XXSP Case Replacement: 步骤 13 中的图像 1,2 Anbernic RG35XXSP Case Replacement: 步骤 13 中的图像 2,2
    • Detach the plastic screen cover from the device.
  14. Anbernic RG35XXSP Case Replacement: 步骤 14 中的图像 1,3 Anbernic RG35XXSP Case Replacement: 步骤 14 中的图像 2,3 Anbernic RG35XXSP Case Replacement: 步骤 14 中的图像 3,3
    • Use the pointed end of a spudger to push the last pin out of the hinge.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 44
总计 255
