跳转到主内容
American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement
你所需要的
  1. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the sandpaper disc: 步骤 1 中的图像 1,1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement: 步骤 2 中的图像 1,1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: 步骤 3 中的图像 1,2 American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: 步骤 3 中的图像 2,2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
结论
4等其他人完成本指南。
Adam O'Camb
于04/11/15注册
197,111 声望
创作了416篇指南
一条评论
replace all three driver pads
THOMAS - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 90
总计 3,641
