跳转到主内容
Ambient Weather WS-1001-Wifi Push Button Replacement
你所需要的
  1. Ambient Weather WS-1001-Wifi Push Button Replacement, Push Button: 步骤 1 中的图像 1,2 Ambient Weather WS-1001-Wifi Push Button Replacement, Push Button: 步骤 1 中的图像 2,2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a small plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Push Button Replacement: 步骤 2 中的图像 1,1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Push Button Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    购买
    • Heat up solder with soldering iron, and quickly use a desoldering gun to remove solder on the pins.
  4. Ambient Weather WS-1001-Wifi Push Button Replacement: 步骤 4 中的图像 1,1
    • Once the button is removed place the new button down on the board.
    • Apply solder with soldering iron to the pins.
结论
Trevor Hansen
于11/06/17注册
104 声望
撰写一个指南
团队
IUPUI, Team S1-G2, Harley Fall 2017 IUPUI, Team S1-G2, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 241
