跳转到主内容
Ambient Weather WS-1001-Wifi Battery Replacement
你所需要的
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: 步骤 1 中的图像 1,2 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: 步骤 2 中的图像 1,1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: 步骤 3 中的图像 1,2 Ambient Weather WS-1001-Wifi Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • The battery can then be popped out using precision tweezers and replaced with a new one.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S1-G2, Harley Fall 2017 IUPUI, Team S1-G2, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S1G2
4 名成员
创作了3篇指南
一条评论
Hello. My screen is not working. And the electric cable is good.
C Kaagman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 787
