跳转到主内容
AmazonBasics BTV1 Motherboard Replacement
你所需要的
  1. AmazonBasics BTV1 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 AmazonBasics BTV1 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Motherboard Replacement: 步骤 2 中的图像 1,2 AmazonBasics BTV1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Motherboard Replacement: 步骤 3 中的图像 1,2 AmazonBasics BTV1 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Motherboard Replacement: 步骤 4 中的图像 1,2 AmazonBasics BTV1 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Gently pull out the two ribbon connectors to disconnect the motherboard from the case.
结论
2等其他人完成本指南。
Chris Shannon
于02/01/16注册
1,039 声望
创作了5篇指南
团队
USF Tampa, Team 14-2, Lacy Spring 2016 USF Tampa, Team 14-2, Lacy Spring 2016 的会员
USFT-LACY-S16S14G2
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 22
总计 641
